주요 콘텐츠로 건너뛰기
Rexing V1P Plus Battery Replacement
필요한 것
  1. Rexing V1P Plus Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Orient the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Battery Replacement: 2 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement: 2 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the back cover of the device and place it to the side, with care not to strain the connected battery cable.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Battery Replacement: 3 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement: 3 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two 5 mm screws on either side of the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Battery Replacement: 4 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement: 4 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Battery Replacement: 5 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement: 5 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 5 mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Battery Replacement: 6 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement: 6 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully remove the plastic frame from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Battery Replacement: 7 단계, 이미지 3개 중 1개 Rexing V1P Plus Battery Replacement: 7 단계, 이미지 3개 중 2개 Rexing V1P Plus Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Using a soldering iron, remove the two wires connecting the battery to the motherboard.
    • Soldering has the potential to burn you or damage your device. Check out this guide before beginning, take appropriate precautions, and always solder in a well-ventilated area.
    • Once the wires are removed, peel the battery off of the case adhesive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Caleb Slentz
회원 가입일: 02/14/23
268 평판
안내서 2개를 작성함
4가이드 댓글
Where is it possible to get the replacement battery? Searching on ebay reveals nothing for the information given.
Derek Piper - 답글
Did you find the replacement capacitors?
Jesse Wamberg -
Just realized this appears to be what is known as a 'super capacitor' rather than a battery so it's possible any 5.5V 3.5Farad capacitor will work. The form factor may be an issue though.
Derek Piper - 답글
Replaced the capacitor and it lasts longer but will still lose date and time over night, so probably another component went bad causing drain. Shame.
Robin W - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 88
전체 시간: 2,892
