주요 콘텐츠로 건너뛰기
Ridgid JobMax R2851 Series B Cord Replacement
필요한 것
  1. Ridgid JobMax R2851 Series B Cord Replacement, Motor: 1 단계, 이미지 1/2 Ridgid JobMax R2851 Series B Cord Replacement, Motor: 1 단계, 이미지 2/2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Cord Replacement: 2 단계, 이미지 1/1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Cord Replacement: 3 단계, 이미지 1/1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Cord Replacement: 4 단계, 이미지 1/2 Ridgid JobMax R2851 Series B Cord Replacement: 4 단계, 이미지 2/2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Cord Replacement: 5 단계, 이미지 1/3 Ridgid JobMax R2851 Series B Cord Replacement: 5 단계, 이미지 2/3 Ridgid JobMax R2851 Series B Cord Replacement: 5 단계, 이미지 3/3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Cord Replacement: 6 단계, 이미지 1/2 Ridgid JobMax R2851 Series B Cord Replacement: 6 단계, 이미지 2/2
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Cord Replacement: 7 단계, 이미지 1/2 Ridgid JobMax R2851 Series B Cord Replacement: 7 단계, 이미지 2/2
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
  8. Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: 8 단계, 이미지 1/3 Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: 8 단계, 이미지 2/3 Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: 8 단계, 이미지 3/3
    • Pinch the brush and pry upward away from the center of the part to remove from the device.
    • Take care to not damage the connections on the bottom of the brush.
  9. Ridgid JobMax R2851 Series B Cord Replacement: 9 단계, 이미지 1/2 Ridgid JobMax R2851 Series B Cord Replacement: 9 단계, 이미지 2/2
    • Firmly hold the brush in one hand and pull at the base of the wire to disconnect.
  10. Ridgid JobMax R2851 Series B Cord Replacement, Cord: 10 단계, 이미지 1/1
    • Cut glue holding down the cord.
    • Take care to not damage the casing or cord when cutting the glue.
  11. Ridgid JobMax R2851 Series B Cord Replacement: 11 단계, 이미지 1/1
    • Lift the cord up and out of the device.
  12. Ridgid JobMax R2851 Series B Cord Replacement: 12 단계, 이미지 1/1
    • Cut through each of the two wires connecting the cord to the device.
    • Keep in mind that you should cut the wires far enough down to re-wire the device.
    • Strip the wires and solder the replacement cord.
    • Wrap the soldered area in electrical tape before putting the device back together.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brent Shepherd
회원 가입일: 02/12/19
884 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 469
