주요 콘텐츠로 건너뛰기
Ridgid R82005 Trigger Switch Replacement
필요한 것
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: 1 단계, 이미지 1/1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: 2 단계, 이미지 1/1
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: 3 단계, 이미지 1/3 Ridgid R82005 Trigger Switch Replacement: 3 단계, 이미지 2/3 Ridgid R82005 Trigger Switch Replacement: 3 단계, 이미지 3/3
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: 4 단계, 이미지 1/3 Ridgid R82005 Trigger Switch Replacement: 4 단계, 이미지 2/3 Ridgid R82005 Trigger Switch Replacement: 4 단계, 이미지 3/3
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alex Cominos
회원 가입일: 02/14/19
376 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 회원
USFT-LEAHY-S19S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 410
