주요 콘텐츠로 건너뛰기
Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement
필요한 것
  1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: 1 단계, 이미지 1개 중 1개
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
  2. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
  3. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 3 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the device over and remove the top casing from the sender.
  4. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Wireless Audio Module Chip: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
  5. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
  6. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
  7. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 7 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 7 단계, 이미지 2개 중 2개
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
  8. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 8 단계, 이미지 1개 중 1개
    • Flip over the motherboard and wireless audio module chip.
  9. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
  10. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: 10 단계, 이미지 1개 중 1개
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
  11. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: 11 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: 11 단계, 이미지 2개 중 2개
    • Desolder the four metallic clasps that attach the panel to the motherboard.
    • For soldering techniques, follow the step in iFixit's soldering guide.
    • Do not attempt to solder if you are inexperienced.
결론
To attach a new speaker input terminal, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Caitlin Charlton
회원 가입일: 03/22/15
756 평판
안내서 6개를 작성함
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G2
3 회원들
안내서 6개를 작성함
1가이드 댓글
Where can I get a replacement input terminal?
Greg Surrett (terminal case) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 2,473
