주요 콘텐츠로 건너뛰기
Roku 2 A/C Power Port Replacement
필요한 것
  1. Roku 2  A/C Power Port Replacement, Roku 2 Motherboard: 1 단계, 이미지 1/1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2  A/C Power Port Replacement: 2 단계, 이미지 1/1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2  A/C Power Port Replacement: 3 단계, 이미지 1/1
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2  A/C Power Port Replacement: 4 단계, 이미지 1/1
    • Gently remove the under side of the device.
  5. Roku 2  A/C Power Port Replacement: 5 단계, 이미지 1/1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2  A/C Power Port Replacement: 6 단계, 이미지 1/1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2  A/C Power Port Replacement: 7 단계, 이미지 1/1
    • Remove the board from the plastic enclosure.
  8. Roku 2  A/C Power Port Replacement, A/C Power Port: 8 단계, 이미지 1/1
    • Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
    • To learn more about soldering check out the Soldering Technique Guide.
  9. Roku 2  A/C Power Port Replacement: 9 단계, 이미지 1/1
    • Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
결론
david quintana
회원 가입일: 08/27/15
101 평판
안내서 1개 작성함
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,298
