소개
This guide will demonstrate how to remove and replace the A/C power port. Be sure to check out the Soldering Technique Guide to learn ore about soldering before completing this repair.
필요한 것
Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
거의 끝나갑니다!
결론
