주요 콘텐츠로 건너뛰기
Roku 3 A/C Power Port Replacement
필요한 것
  1. Roku 3 A/C Power Port Replacement, Motherboard: 1 단계, 이미지 1/1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 A/C Power Port Replacement: 2 단계, 이미지 1/3 Roku 3 A/C Power Port Replacement: 2 단계, 이미지 2/3 Roku 3 A/C Power Port Replacement: 2 단계, 이미지 3/3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 A/C Power Port Replacement: 3 단계, 이미지 1/1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 A/C Power Port Replacement: 4 단계, 이미지 1/2 Roku 3 A/C Power Port Replacement: 4 단계, 이미지 2/2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 A/C Power Port Replacement: 5 단계, 이미지 1/1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 A/C Power Port Replacement: 6 단계, 이미지 1/2 Roku 3 A/C Power Port Replacement: 6 단계, 이미지 2/2
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 A/C Power Port Replacement, A/C Power Port: 7 단계, 이미지 1/2 Roku 3 A/C Power Port Replacement, A/C Power Port: 7 단계, 이미지 2/2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 A/C Power Port Replacement: 8 단계, 이미지 1/1
    • Desolder the connections of the A/C Power Port on the motherboard.
    • Remove the port.
    • For more information on soldering, check out iFixit's Soldering Guide.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andy Hak
회원 가입일: 10/07/16
250 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G2
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
What’s the size and name of the actual jack? Where do I get a replacement one?
Bo Northwest Designs of SE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 2,480
