주요 콘텐츠로 건너뛰기
Roku XD 2050X Audio Port Replacement
필요한 것
  1. Roku XD 2050X Audio Port Replacement, Case: 1 단계, 이미지 1/3 Roku XD 2050X Audio Port Replacement, Case: 1 단계, 이미지 2/3 Roku XD 2050X Audio Port Replacement, Case: 1 단계, 이미지 3/3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Audio Port Replacement: 2 단계, 이미지 1/2 Roku XD 2050X Audio Port Replacement: 2 단계, 이미지 2/2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Audio Port Replacement: 3 단계, 이미지 1/3 Roku XD 2050X Audio Port Replacement: 3 단계, 이미지 2/3 Roku XD 2050X Audio Port Replacement: 3 단계, 이미지 3/3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Audio Port Replacement: 4 단계, 이미지 1/2 Roku XD 2050X Audio Port Replacement: 4 단계, 이미지 2/2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Audio Port Replacement: 5 단계, 이미지 1/1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Audio Port Replacement, Audio Port: 6 단계, 이미지 1/1
    • Desolder the leads for the audio port that you wish to replace.
    • Left audio port leads are circled in red.
    • Right audio port leads are circled in orange.
    • Remove the audio port from board.
    • For help with soldering view the iFixit soldering guide.
결론
William
회원 가입일: 01/30/15
1,603 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 443
