주요 콘텐츠로 건너뛰기
Roku XD 2050X Remote Battery Terminal Replacement
필요한 것
  1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: 1 단계, 이미지 1/2 Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: 1 단계, 이미지 2/2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Battery Terminal Replacement: 2 단계, 이미지 1/2 Roku XD 2050X Remote Battery Terminal Replacement: 2 단계, 이미지 2/2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Battery Terminal Replacement: 3 단계, 이미지 1/1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Battery Terminal Replacement: 4 단계, 이미지 1/1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Battery Terminal Replacement: 5 단계, 이미지 1/1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Battery Terminal Replacement, Remote Battery Terminal: 6 단계, 이미지 1/1
    • Desolder the contacts for the battery terminals.
    • Remove the battery terminals from the circuit board.
    • For hep with soldering view the ifixit soldering guide.
결론
William
회원 가입일: 01/30/15
1,603 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 1,243
