주요 콘텐츠로 건너뛰기
SCUF Reflex Joystick Replacement
필요한 것
  1. SCUF Reflex Joystick Replacement, Remove the middle trim: 1 단계, 이미지 1개 중 1개
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips.
    • Loosen the rest of the clips and take the middle trim out.
  2. SCUF Reflex Joystick Replacement, Remove L1 and R1: 2 단계, 이미지 3개 중 1개 SCUF Reflex Joystick Replacement, Remove L1 and R1: 2 단계, 이미지 3개 중 2개 SCUF Reflex Joystick Replacement, Remove L1 and R1: 2 단계, 이미지 3개 중 3개
    • Use a tool to pop the R1 and L1 buttons off of the controller.
  3. SCUF Reflex Joystick Replacement, Unscrew the grips: 3 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement, Unscrew the grips: 3 단계, 이미지 2개 중 2개
    • Unscrew and remove the screw from the bottom of each grip.
  4. SCUF Reflex Joystick Replacement, Unscrew behind L1 and R1: 4 단계, 이미지 1개 중 1개
    • Unscrew the screws behind the L1 and R1 buttons.
  5. SCUF Reflex Joystick Replacement, Pull the joysticks off: 5 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement, Pull the joysticks off: 5 단계, 이미지 2개 중 2개
    • Pull the joysticks off of the controller.
  6. SCUF Reflex Joystick Replacement, Pull the scuff buttons off: 6 단계, 이미지 1개 중 1개
    • Pull the scuff buttons off the back of the controller by sliding them down.
  7. SCUF Reflex Joystick Replacement, Remove the rear case: 7 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement, Remove the rear case: 7 단계, 이미지 2개 중 2개
    • Slide the prying tool down the edge of the rear casing of the controller to remove the rear case.
    • Be sure to deal with all the clips!
  8. SCUF Reflex Joystick Replacement, Slide the battery out: 8 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement, Slide the battery out: 8 단계, 이미지 2개 중 2개
    • Slide the battery out of the controller. It's grey and held in by a couple of wires, so be careful not to damage them.
  9. SCUF Reflex Joystick Replacement, Unplug the battery: 9 단계, 이미지 1개 중 1개
    • Unplug the battery to finish removing the battery from the controller.
  10. SCUF Reflex Joystick Replacement, Take the battery bracket out: 10 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement, Take the battery bracket out: 10 단계, 이미지 2개 중 2개
    • Unscrew the screw on the back of the controller to remove the battery bracket.
  11. SCUF Reflex Joystick Replacement, Desolder the ribbon cables: 11 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement, Desolder the ribbon cables: 11 단계, 이미지 2개 중 2개
    • Use a soldering iron to desolder the ribbon cables on the motherboard.
  12. SCUF Reflex Joystick Replacement: 12 단계, 이미지 1개 중 1개
    • Unplug these four cables from the motherboard.
  13. SCUF Reflex Joystick Replacement: 13 단계, 이미지 1개 중 1개
    • Use the soldering iron to desolder the black and red wires off of the motherboard.
  14. SCUF Reflex Joystick Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the motherboard and the battery bracket from the controller to expose the joystick component.
  15. SCUF Reflex Joystick Replacement: 15 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Use the soldering iron and the desoldering pump to desolder the 14 connections for the component.
  16. SCUF Reflex Joystick Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the component from the motherboard.
  17. SCUF Reflex Joystick Replacement: 17 단계, 이미지 2개 중 1개 SCUF Reflex Joystick Replacement: 17 단계, 이미지 2개 중 2개
    • Put the new component on the motherboard.
    • Use the soldering iron to connect the new component to the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tri Truong
회원 가입일: 02/13/23
435 평판
안내서 2개를 작성함
1가이드 댓글
Hi! Wich replacement component do you use?
Antonis Lambropoulos - 답글
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 182
지난 30일: 797
전체 시간: 15,921
