주요 콘텐츠로 건너뛰기
SONY ZS-BTG900 CD Player Drive Replacement
필요한 것
  1. SONY ZS-BTG900 CD Player Drive Replacement, SONY ZS-BTG900 Disassembly: 1 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement, SONY ZS-BTG900 Disassembly: 1 단계, 이미지 2/2
    • Lift up the handle to reveal the screws.
    • Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
  2. SONY ZS-BTG900 CD Player Drive Replacement: 2 단계, 이미지 1/3 SONY ZS-BTG900 CD Player Drive Replacement: 2 단계, 이미지 2/3 SONY ZS-BTG900 CD Player Drive Replacement: 2 단계, 이미지 3/3
    • Flip your device over.
    • Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
    • In removing the screws within the two holes on the back of the device, you may want to use your shaft extension to provide extra torque as they may be very tight.
  3. SONY ZS-BTG900 CD Player Drive Replacement: 3 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 3 단계, 이미지 2/2
    • Flip your device back over to access the top of the device.
    • Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
    • This will reveal two additional screws.
  4. SONY ZS-BTG900 CD Player Drive Replacement: 4 단계, 이미지 1/1
    • Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
    How do you remove the carrying handle
    Gerald Senchak - 답글
    Seems the handle has to come off before the top….. how does the handle get removed? Thanks!
    Dan Mull - 답글
    Well this is stupid. You don’t show the handle being removed. I bet you broke it. You people don’t know what you are doing.
    Thomas Anderson - 답글
  5. SONY ZS-BTG900 CD Player Drive Replacement: 5 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 5 단계, 이미지 2/2
    • Lift off the top, beginning from the back of the device.
    • Take care when lifting the top portion as there are many wires connected to the inside of the device and you do not want to disconnect these just yet.
  6. SONY ZS-BTG900 CD Player Drive Replacement: 6 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 6 단계, 이미지 2/2
    • Disconnect the CD drive ribbon cable from the top of the device.
  7. SONY ZS-BTG900 CD Player Drive Replacement: 7 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 7 단계, 이미지 2/2
    • Disconnect the antenna cables.
  8. SONY ZS-BTG900 CD Player Drive Replacement: 8 단계, 이미지 1/3 SONY ZS-BTG900 CD Player Drive Replacement: 8 단계, 이미지 2/3 SONY ZS-BTG900 CD Player Drive Replacement: 8 단계, 이미지 3/3
    • Disconnect the remaining cables from the motherboard.
  9. SONY ZS-BTG900 CD Player Drive Replacement: 9 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 9 단계, 이미지 2/2
    • Once you have removed the top, we will begin removing the front of the device.
    • Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
  10. SONY ZS-BTG900 CD Player Drive Replacement: 10 단계, 이미지 1/1
    • Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
  11. SONY ZS-BTG900 CD Player Drive Replacement: 11 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 11 단계, 이미지 2/2
    • Firmly pull off the front of device.
    • There will be a small amount of black glue. You can simply ignore this, and continue to pull, or use a sharp edge to cut the glue once you've revealed it.
  12. SONY ZS-BTG900 CD Player Drive Replacement, CD Player Drive: 12 단계, 이미지 1/1
    • Flip the top and locate the CD module on the right side.
  13. SONY ZS-BTG900 CD Player Drive Replacement: 13 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 13 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to unscrew the four 1/2 inch screws.
  14. SONY ZS-BTG900 CD Player Drive Replacement: 14 단계, 이미지 1/2 SONY ZS-BTG900 CD Player Drive Replacement: 14 단계, 이미지 2/2
    • Firmly grab and lift the CD drive from its plastic compartment to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alfredo Rodriguez
회원 가입일: 04/11/16
972 평판
안내서 8개 작성하였습니다
댓글 한 개
We're can I buy or order the new drive? And possibly a new top for the cd
Fonz G - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 773
