소개
Before attempting this guide, be sure you check out the device troubleshooting page to see if you can get your radio working that way.
If not, we are going to go ahead and open the device as you will need to swap out your radio adapter for a working one.
도구
부품
지정된 부품이 없습니다.
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
