주요 콘텐츠로 건너뛰기
Saeco Minuto (and compatible machines) brewing unit gasket replacement
필요한 것
  1. Saeco Minuto (and compatible machines) brewing unit gasket replacement, Brewing unit gasket: 1 단계, 이미지 2개 중 1개 Saeco Minuto (and compatible machines) brewing unit gasket replacement, Brewing unit gasket: 1 단계, 이미지 2개 중 2개
    • Open the hatch on the side panel and remove the brewing unit.
  2. Saeco Minuto (and compatible machines) brewing unit gasket replacement: 2 단계, 이미지 1개 중 1개
    • The spout for the hot coffee is located on the top of the brewing unit. It is fastened with two screws. Underneath is the crema valve. It consists of a spring and a little glass ball. Make sure the spring is reinserted with the thin end touching the glass ball when re-assembling.
    • Remove the two Torx T10 screws on the crema valve.
    • Lift off the crema valve minding the spring and the glass ball.
  3. Saeco Minuto (and compatible machines) brewing unit gasket replacement: 3 단계, 이미지 1개 중 1개
    • The upper piston is held in place in the frame with four locking pawls. Push down all four latches with a spudger, then remove the piston by pushing it downward.
    • If you want to replace the gasket, you can do this now and re-assemble the device and stop here. However, a general maintenance of the brewing unit is strongly recommended.
    • Unscrew the Torx T10 screw on the brewing sieve and remove it.
  4. Saeco Minuto (and compatible machines) brewing unit gasket replacement: 4 단계, 이미지 3개 중 1개 Saeco Minuto (and compatible machines) brewing unit gasket replacement: 4 단계, 이미지 3개 중 2개 Saeco Minuto (and compatible machines) brewing unit gasket replacement: 4 단계, 이미지 3개 중 3개
    • There are three Torx T10 screws in deep blind holes that hold together the two parts of the brewing unit. Unscrew them and lift off the upper side panel.
  5. Saeco Minuto (and compatible machines) brewing unit gasket replacement: 5 단계, 이미지 2개 중 1개 Saeco Minuto (and compatible machines) brewing unit gasket replacement: 5 단계, 이미지 2개 중 2개
    • Now you can disassemble the brewing unit into its three main parts: the brewing unit and the two side panels.
  6. Saeco Minuto (and compatible machines) brewing unit gasket replacement: 6 단계, 이미지 2개 중 1개 Saeco Minuto (and compatible machines) brewing unit gasket replacement: 6 단계, 이미지 2개 중 2개
    • You can push out the lower piston from the brewing unit if you snap the deflection lever out of its socket with a screw driver.
    • Clean all parts with very hot water and dishwasher liquid.
    • Grease all moving parts with food grade silicone fat. Dont forget the tracks in the side panels.
  7. Saeco Minuto (and compatible machines) brewing unit gasket replacement: 7 단계, 이미지 3개 중 1개 Saeco Minuto (and compatible machines) brewing unit gasket replacement: 7 단계, 이미지 3개 중 2개 Saeco Minuto (and compatible machines) brewing unit gasket replacement: 7 단계, 이미지 3개 중 3개
    • Take this opportunity to carefully replace the two O-rings on the support valve. The larger one is at the top. These two seals are stressed during every brewing process. Therefore, lubricate them with food-safe silicone grease.
    • On some models, the support valve is covered. In this case, you must unscrew the cover first.
결론
Follow the steps in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
299,196 평판
안내서 303개를 작성함
9가이드 댓글
I like the statement that this guide works for many machines that use the Saeco brew group, but it would be great if that were somehow in the title, too. When checking to see whether a guide on this brew group was written, I first skipped this guide because I thought "minuto" referred to a "mini" Saeco.
Christopher Sean Harris - 답글
Thank you for this hint. I placed three links to Saeco, Philips and Gaggia coffeemakers.
VauWeh -
Hello all, I have a saeco minuto model HD8867. I have o. Screen error 23 but it feel like error 4. I have entered in test menu and all ar on parameters. Is there another way to reset this machine?
Florin Pop Piglesan - 답글
@florinpopp16782 This is an issue with the "CoffeeSwitch" for either espresso or coffee. I have two informations for you,both in german, you need a translation app: iFixit and a forum.
VauWeh -
Hello VauWeh, Thank you for your response. My model HD8867 does not have a "CoffeeSwitch". I have seen this and checked for it. I want to mention that I was able to go in Test mode and test all the components, and all fine. I have found this morning another hint. that I can maybe go back to factory parameters and delete some errors from memory that maybe it is hanging. If not I dont have other ideas.
To enter in SteamOut
The machine enters SteamOut mode by holding pressed together the COFFEE button and the MENU button while switching on the machine
When the Steam-Out is complete the following parameters are reset to their default values:
· Length Espresso product
· Length Coffee product
· Length Cappuccino (Coffee + Milk product)
· Length Milk product
· StandBy Time
· Count Coffee
· The request for Priming the Circuit at the fifi rst switch on is set.
· Brewing Unit Empty
· Aroma
· Aroma Impulses
· Filter Presence
· Filter Pulses
· Dynamic threshold
· History of grindings for Beans Presence detection· Filter Presence
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 31
지난 30일: 189
전체 시간: 7,229
