주요 콘텐츠로 건너뛰기
Samsung 27E510C Audio Jack Replacement
필요한 것
  1. Samsung 27E510C Audio Jack Replacement, Back Panel: 1 단계, 이미지 1/3 Samsung 27E510C Audio Jack Replacement, Back Panel: 1 단계, 이미지 2/3 Samsung 27E510C Audio Jack Replacement, Back Panel: 1 단계, 이미지 3/3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Audio Jack Replacement: 2 단계, 이미지 1/2 Samsung 27E510C Audio Jack Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    구매
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C Audio Jack Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C Audio Jack Replacement: 4 단계, 이미지 1/1
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C Audio Jack Replacement: 5 단계, 이미지 1/3 Samsung 27E510C Audio Jack Replacement: 5 단계, 이미지 2/3 Samsung 27E510C Audio Jack Replacement: 5 단계, 이미지 3/3
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C Audio Jack Replacement: 6 단계, 이미지 1/3 Samsung 27E510C Audio Jack Replacement: 6 단계, 이미지 2/3 Samsung 27E510C Audio Jack Replacement: 6 단계, 이미지 3/3
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C Audio Jack Replacement: 7 단계, 이미지 1/2 Samsung 27E510C Audio Jack Replacement: 7 단계, 이미지 2/2
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C Audio Jack Replacement, Audio Jack: 8 단계, 이미지 1/2 Samsung 27E510C Audio Jack Replacement, Audio Jack: 8 단계, 이미지 2/2
    • Desolder each of the indicated leads on the back of the motherboard.
  9. Samsung 27E510C Audio Jack Replacement: 9 단계, 이미지 1/2 Samsung 27E510C Audio Jack Replacement: 9 단계, 이미지 2/2
    • Squeeze the rear tabs located on the back of the motherboard with your thumb and index finger.
    • While squeezing both tabs, pull the audio jack out from the front of the motherboard.
    • The audio jack may be too hot to touch right after desoldering.
결론
Cesar Morales
회원 가입일: 09/27/17
101 평판
안내서 1개 작성함
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G1
6 회원들
안내서 14개 작성하였습니다
댓글 한 개
did you know port reference? @cesarmorales
Jorge Casanova - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 475
