소개
The VGA Port allows for an external source to display an image onto the monitor by using a VGA cable. If the VGA Port is damaged, an image might not display onto the monitor.
필요한 것
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
거의 끝나갑니다!
결론
