소개
The VGA Port allows for an external source to display an image onto the monitor by using a VGA cable. If the VGA Port is damaged, an image might not display onto the monitor.
필요한 것
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
거의 끝나갑니다!
결론
