주요 콘텐츠로 건너뛰기
Samsung ATIV Book 4 Mouse Pad Replacement
필요한 것
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 1 단계, 이미지 1/3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 1 단계, 이미지 2/3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 1 단계, 이미지 3/3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: 2 단계, 이미지 1/1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: 3 단계, 이미지 1/2 Samsung ATIV Book 4 Mouse Pad Replacement: 3 단계, 이미지 2/2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: 4 단계, 이미지 1/2 Samsung ATIV Book 4 Mouse Pad Replacement: 4 단계, 이미지 2/2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
결론
Daniel
회원 가입일: 03/19/15
342 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 회원
MTU-LAUER-S15S1G7
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,095
