주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung ATIV Book 4 Battery Replacement
필요한 것
  1. Samsung ATIV Book 4 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung ATIV Book 4 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the computer upside down.
    • Remove 2 rubber pads, by prying up on them.
    • There may be adhesive holding them down. If this is the case, the plastic opening tool may be needed to remove them.
    • Remove the seven 6.5mm screws on exterior of computer.
    댓글 쓰기
  2. Samsung ATIV Book 4 Battery Replacement: 2 단계, 이미지 2개 중 1개 Samsung ATIV Book 4 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the panel by sliding it down and lifting it away from the computer.
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
    댓글 쓰기
  3. Samsung ATIV Book 4 Battery Replacement: 3 단계, 이미지 2개 중 1개 Samsung ATIV Book 4 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer, once all tabs are broken free.
    댓글 쓰기
  4. Samsung ATIV Book 4 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four 3.5mm screws holding the battery.
    • Peel back the tape securing the wires to the battery.
    • Lift and remove the battery from its location.
    • Don't pull/tear the wires connected to battery harness.
    댓글 쓰기
  5. Samsung ATIV Book 4 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the battery harness from computer.
    • Completely remove the battery and replace it.
    댓글 쓰기
  6. Samsung ATIV Book 4 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Plug battery harness back in.
    • Assure the wires are pointed up (towards you) then plugging back in, as shown.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chad
회원 가입일: 03/17/15
443 평판
안내서 2개를 작성함
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 회원
MTU-LAUER-S15S1G7
2 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 53
전체 시간: 10,620
