주요 콘텐츠로 건너뛰기
Samsung BD-JM57C Open Button Replacement
필요한 것
  1. Samsung BD-JM57C Open Button Replacement, Top Cover: 1 단계, 이미지 1/2 Samsung BD-JM57C Open Button Replacement, Top Cover: 1 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Open Button Replacement, Disc Drive: 2 단계, 이미지 1/2 Samsung BD-JM57C Open Button Replacement, Disc Drive: 2 단계, 이미지 2/2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Open Button Replacement: 3 단계, 이미지 1/2 Samsung BD-JM57C Open Button Replacement: 3 단계, 이미지 2/2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Open Button Replacement, WiFi Card: 4 단계, 이미지 1/2 Samsung BD-JM57C Open Button Replacement, WiFi Card: 4 단계, 이미지 2/2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Open Button Replacement, Power Cord: 5 단계, 이미지 1/2 Samsung BD-JM57C Open Button Replacement, Power Cord: 5 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Open Button Replacement: 6 단계, 이미지 1/1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Open Button Replacement: 7 단계, 이미지 1/1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Open Button Replacement: 8 단계, 이미지 1/1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  9. Samsung BD-JM57C Open Button Replacement, Motherboard: 9 단계, 이미지 1/1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  10. Samsung BD-JM57C Open Button Replacement: 10 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  11. Samsung BD-JM57C Open Button Replacement: 11 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
  12. Samsung BD-JM57C Open Button Replacement, Open Button: 12 단계, 이미지 1/1
    • Locate the Open Button on the circuit board.
  13. Samsung BD-JM57C Open Button Replacement: 13 단계, 이미지 1/1
    • Flip the motherboard over so that the green side is facing you.
    • Use a soldering iron to desolder the two points to disconnect the open button.
    • For more information on soldering, please read the How To Solder and Desolder Connections guide.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Abby Hudson
회원 가입일: 01/14/20
637 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 1,368
