주요 콘텐츠로 건너뛰기
Samsung Epic 4G Touch microSD Card Replacement
필요한 것
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: 2 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch microSD Card Replacement: 2 단계, 이미지 2개 중 2개
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: 3 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: 3 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the microSD card away from its slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Walter Galan
706,370 평판
안내서 1,203개를 작성함
2가이드 댓글
Uhh.... my Australian SGSII looks different to this...
Bonj - 답글
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 4,514
