주요 콘텐츠로 건너뛰기
Samsung Galaxy A5 (2016) Display Replacement
필요한 것
  1. Samsung Galaxy A5 (2016) Display Replacement, Back Cover: 1 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement, Back Cover: 1 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement, Back Cover: 1 단계, 이미지 3/3
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • With a suction handle lift the back cover to insert an opening pick.
  2. Samsung Galaxy A5 (2016) Display Replacement: 2 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 2 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 2 단계, 이미지 3/3
    • Slide the pick up to the middle to separate the back cover from the frame.
    • Insert a second opening pick and move around the right corner along the bottom and around the left corner.
  3. Samsung Galaxy A5 (2016) Display Replacement: 3 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 3 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 3 단계, 이미지 3/3
    • Take another opening pick and continue towards the top corner.
    • Here you want to use one more pick for the last part at the top.
  4. Samsung Galaxy A5 (2016) Display Replacement: 4 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 4 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Insert a plastic card at the bottom and slide it underneath the back cover.
  5. Samsung Galaxy A5 (2016) Display Replacement: 5 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 5 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 5 단계, 이미지 3/3
    • Heat up the back cover once again so you can slide the plastic card towards the top.
    • Always take a peek underneath the back cover to not damage any parts like the NFC antenna.
    • Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Be sure to remove any residue from the glue and apply new adhesive when reassembling.
  6. Samsung Galaxy A5 (2016) Display Replacement, Display: 6 단계, 이미지 1/2 Samsung Galaxy A5 (2016) Display Replacement, Display: 6 단계, 이미지 2/2
    • Remove the SIM card tray.
    • Remove the 17 Phillips #00 screws on the midframe.
  7. Samsung Galaxy A5 (2016) Display Replacement: 7 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 7 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 7 단계, 이미지 3/3
    • Push the exposed part of the battery away from the midframe to separate the components.
    • You may need the IMEI sticker on your old battery to identify your phone in the future, be sure to transfer it to the replacement battery.
  8. Samsung Galaxy A5 (2016) Display Replacement: 8 단계, 이미지 1/2 Samsung Galaxy A5 (2016) Display Replacement: 8 단계, 이미지 2/2
    • With a flat end of a spudger disconnect the display connector.
    • Reheat the iOpener and use it to loosen the adhesive under the display.
  9. Samsung Galaxy A5 (2016) Display Replacement: 9 단계, 이미지 1/2 Samsung Galaxy A5 (2016) Display Replacement: 9 단계, 이미지 2/2
    • Use a Jimmy to get between the frame and the front panel.
    • Pry up the display unit just a bit so you can put an opening pick behind the display.
    • You just want to insert the tip of the opening pick where the display cable is.
    • Slide down the side to separate the glue. At the bottom you can insert the opening pick further to keep the adhesive from resealing.
  10. Samsung Galaxy A5 (2016) Display Replacement: 10 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 10 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 10 단계, 이미지 3/3
    • Repeat the same procedure on the other side.
    • Here you can insert the opening pick as far as half of an inch to get the glue off behind the battery.
    • Slide down to where the display ends.
  11. Samsung Galaxy A5 (2016) Display Replacement: 11 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 11 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 11 단계, 이미지 3/3
    • Now slide along the bottom to get the glue off.
    • Be careful, there are two touch buttons on each side behind the front panel. In the middle only go as deep as where the home button begins.
  12. Samsung Galaxy A5 (2016) Display Replacement: 12 단계, 이미지 1/1
    • Re-heat the display unit for the next few steps.
  13. Samsung Galaxy A5 (2016) Display Replacement: 13 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 13 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • On the left hand side (where the motherboard sits) replace the opening pick with a plastic card to get to the glue behind the battery.
    • Continue separating the adhesive until you reach the display cable.
  14. Samsung Galaxy A5 (2016) Display Replacement: 14 단계, 이미지 1/3 Samsung Galaxy A5 (2016) Display Replacement: 14 단계, 이미지 2/3 Samsung Galaxy A5 (2016) Display Replacement: 14 단계, 이미지 3/3
    • Separate the display from the display frame and cut the remaining glue at the top with an opening pick.
    • Carefully slide the display cable out of the slot in the display frame.
  15. Samsung Galaxy A5 (2016) Display Replacement: 15 단계, 이미지 1/1
    • Before you start reassembling plug the new display to the motherboard and perform a short test by powering on your phone. See if the display lights up and the touch works properly.
    • Remove any adhesive from the display and rear glass and reapply as necessary.
결론
다른 63명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,598 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 8개
dear sir,
i follow the steps above but still my mobile with black screen and colored dots, what shall i do please help me
mohammad khateeb - 답글
Dear sir
Mera Mobile gir jane ke karan screen tut gya h but work kar rha mai chahta hu ise repair karwana please contact me Mobile -7903248447
PAWAN KUMAR - 답글
Miei parole ci sono sei molto bravo , grazie mille per tutorial , e ti mandò un mondo di salute e più grande fortuna dell' mondo Grazie…..
Teofil Timis - 답글
Evo da i ja ostavim komentar. kad vec svako na svoj jezik pise
sturman - 답글
Unfortunately, Croatian is not yet available on our site. A team of volunteers has already started localizing the iFixit user interface into Croatian, but there is still lots of work to do. We are using an open web translation software which is called "Crowdin". If you'd like to participate, you can just follow this link and create an account to start translating: https://crowdin.com/project/ifixit/hr# , but I would recommend that you read the iFixit translator guidelines first: Translator Guidelines Crowdin. If you’d like to get a notification as soon as we get started with Guide and Wiki translations in Croatian, you can just fill in this form:++ https://docs.google.com/forms/d/e/1FAIpQ.... I stay at your disposal for any further question or concern!
Sandra Hiller -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 32
30일 전: 102
전체 시간: 63,587
