소개
Use this guide to replace the battery in your Galaxy Book Pro 360 15" laptop with a genuine Samsung part.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick along the bottom edge to release the clips securing the rear case.
Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
Gently pry up and disconnect the battery connector from its socket.
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the battery.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
Barbara here. Where can I get a battery for my Galaxy 2 Book? It appears to be irreplacable! I spilled water under my laptop, the battery corroded and I work off plug in only now. Nothing works without daily and frequent 'network reset'
Can you help?
bejohnstone@btinternet.com
Northern Ireland
Hi Barbara! It looks like we're out of stock, but you can enter your email on this site to be notified when it's back in stock. You could also look on eBay or Amazon for the battery. The part number is BA96-07916A and the battery model number is AA-PBMN4VN.
Easy! Great guide!
