소개
Use this guide to replace the touchpad in your Galaxy Book Pro 360 15" laptop with a genuine Samsung part.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick along the bottom edge to release the clips securing the rear case.
Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
Gently pry up and disconnect the battery connector from its socket.
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the battery.
Use your fingers or a spudger to peel up the tape covering the ZIF connector on the touchpad.
Remove the tape.
Use the pointed end up a spudger to pry up the locking flap on the ZIF connector.
Use a Phillips #00 screwdriver to remove the five 1.7 mm screws securing the touchpad.
Open the laptop to about a 45 degree angle, keeping the laptop upside down.
Push up on the touchpad until its top edge is freed from the frame.
Pull the touchpad towards the top of the laptop and remove it.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
