주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Prime Motherboard Replacement
필요한 것
  1. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 2 단계, 이미지 1/3 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 2 단계, 이미지 2/3 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 2 단계, 이미지 3/3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 3 단계, 이미지 1/3 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 3 단계, 이미지 2/3 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 3 단계, 이미지 3/3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement: 4 단계, 이미지 2/2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Motherboard Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement: 5 단계, 이미지 2/2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: 6 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: 6 단계, 이미지 2/2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: 7 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: 7 단계, 이미지 2/2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Motherboard Replacement: 10 단계, 이미지 1/3 Samsung Galaxy Grand Prime Motherboard Replacement: 10 단계, 이미지 2/3 Samsung Galaxy Grand Prime Motherboard Replacement: 10 단계, 이미지 3/3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Motherboard Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Grand Prime Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
결론
다른 86명이 해당 안내서를 완성하였습니다.
Kyle Ruff
회원 가입일: 02/04/16
6,749 평판
안내서 5개 작성하였습니다
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G3
3 회원들
안내서 12개 작성하였습니다
댓글 12개
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
Glo - 답글
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
connectedcellrepair -
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
Lisa Yates - 답글
My grand prime 4g board damage
Rakesh - 답글
My grand prime 4g mother board damage
Rakesh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 111
전체 시간: 53,316
