주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Use this guide to replace the display.
  1. Heat the surface of the display with a heatgun for approx. 2 minutes at 200°C.
    • Heat the surface of the display with a heatgun for approx. 2 minutes at 200°C.
  2. Insert an iFixit Jimmy between the display and the rest of the device, and carefully cut through the adhesive around the phone.
    • Insert an iFixit Jimmy between the display and the rest of the device, and carefully cut through the adhesive around the phone.
  3. Loosen the display, while still applying heat with the heat gun.
    • Loosen the display, while still applying heat with the heat gun.
    • The display may shatter.
    • Carefully remove any broken glass with a vacuum.
  4. Remove the cover on the display connector.
    • Remove the cover on the display connector.
    • Remove the display connector.
  5. Remove remnants of the old display and  clean the phone. Remove remnants of the old display and  clean the phone. Remove remnants of the old display and  clean the phone.
    • Remove remnants of the old display and clean the phone.
  6. Leave the original liner on the new display. Plug the new display in and test it.
    • Leave the original liner on the new display. Plug the new display in and test it.
    • Turn the phone off again.
  7. Remove the liners.
    • Remove the liners.
    • Stick the new display to the phone.
  8. Finished.
    • Finished.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Patrick Müller
회원 가입일: 2018년 12월 27일
171 평판
안내서 1개 작성함
Heißluftgebläse … 404
tcagle53 - 답글
Quick, simple, easy to follow and to the point guide. Thanks for taking the time to write it. Great reference for my repairs!
Jason - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 81
30일 전: 373
전체 시간: 3,960
