소개
This guide shows yow to replace the display of your Samsung Galaxy M20 - SM-205FN.
필요한 것
Loosen the back cover
To do this, start at the headphone jack and lever between the back cover and the rest of the phone.
Keep going around the seam until the back cover is loose. Before fully taking off the back cover, carefully disconnect the fingerprint sensor's ribbon cable using a spudger or tweezers.
Now you should heat the entire front, either with a cherry stone pillow (wheat bag) or a heating plate, hair dryer, ironing on a low level is also possible if necessary.
Then use a plastic tool to pry the top of the camera. BE CAREFUL not to break the camera. Then go around and loosen the display. Reheat if necessary.
Pull the cable out of the slot at the bottom, clean the edges.
FINISHED!
Reverse the steps to reassemble your device. I am not responsible for any damage to your device.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
