주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 10.1 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: 1 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: 1 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: 1 단계, 이미지 3/3
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: 2 단계, 이미지 3/3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: 3 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: 3 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: 3 단계, 이미지 3/3
    • Carefully remove all of the ribbons that connect over the battery.
  4. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: 4 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: 4 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: 4 단계, 이미지 3/3
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
  5. Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Flip the tablet 180 degrees for this step so the motherboard is easier to access.
    • Disconnect the cable connectors from the motherboard by gently lifting the connection hubs.
    • Remove each ribbon cable by lifting the locking mechanism on the casing holding the cable.
    • Gently pull the ribbon cable from the casing with your fingers or tweezers.
    • Carefully remove ribbon cables. Ribbon cables are easy to damage and may not always appear damaged. Any damage could potentially cause your device not to work.
  6. Samsung Galaxy Note 10.1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard by gently sliding it out of its casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Rachel Dykes
회원 가입일: 11/04/19
205 평판
안내서 2개 작성하였습니다
Idaho State University, Team S1-G4, Watkins Fall 2019 Idaho State University, Team S1-G4, Watkins Fall 2019 회원
ISU-WATKINS-F19S1G4
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 2,580
