주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4 Battery Replacement
필요한 것
  1. Samsung Galaxy Note 4 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
결론
다른 54명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,953 평판
안내서 89개 작성하였습니다
댓글 9개
I updated my phone and the problem is that my phone just goes all black all the time and my phone it won't turn on and sometimes my phone restarts by itself and after the carrier goes on and on after a few mins it repeatedly goes black.
Can someone please me what's wrong with my phone. I have a Samsung Note 4.
Jessica Lee - 답글
Seems like your mobile device may be stuck in whats called, BootLoop Mode.
Gabe -
Yeah. One time my Note 4 did that too. It has an Otter case. What happened was I put the phone in topside down position into the rubber part. By mistake, of course. Corrected that and the problem was solved.
Tony -
Each time I trimmed my nails. It was impossible to open the back cover and had to use a mini screwdriver to open. Quite inconvenient. So I attached a small piece of clear packing tape (not the flimsy Scotchtape) to the inside of the cover's recess, with enough length sticking out to the side. Grab that tape and pull back on the cover. Voila. The otter case covers the tape, so the phone looks normal in use.
Tony -
hi
can i now its Compatibility with note 4 ( 2 sim ) ???? or Compatibility with 1 sim ????
aigoostore - 답글
hello
my phone’s battery empty very fast, this happen after the last update.
can someone tell me whats wrong with the battery?
thank you
Mona Al-Shaikh - 답글
my phone turns on and than it works for a second and than it trys to rebute by its self and i dont know how to fix it so i kinda need help on geting it fixed
Anthany Kleven - 답글
My battery charges to full while on the charger then dies to 0% after about 5 minutes. ID this Just a new battery that’s required or is it a connection problem?
thanks
joshuacohen16 - 답글
This is... impossible....
Edward Ramirez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 74
전체 시간: 33,045
