소개
Use this guide to replace the battery in your Galaxy Note.
If your battery is swollen, take appropriate precautions.
필요한 것
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I find a cheap, yet powerful battery as a replacement for the old? How do I tell if the device needs a new battery or if the charging port needs to be repaired in its entirety?
