주요 콘텐츠로 건너뛰기
Samsung Galaxy Note Micro USB Port Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Samsung Galaxy Note Micro USB Port Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy Note Micro USB Port Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy Note Micro USB Port Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Micro USB Port Replacement: 2 단계, 이미지 1/1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Micro USB Port Replacement: 3 단계, 이미지 1/1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Micro USB Port Replacement, Midframe: 4 단계, 이미지 1/1
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Micro USB Port Replacement: 5 단계, 이미지 1/1
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Micro USB Port Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Note Micro USB Port Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Note Micro USB Port Replacement: 6 단계, 이미지 3/3
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
  7. Samsung Galaxy Note Micro USB Port Replacement, Micro USB Port: 7 단계, 이미지 1/1
    • Turn the phone so the screen is on the table and the USB port is facing you.
    • Disconnect the orange ribbon near the bottom of the device using a spudger.
  8. Samsung Galaxy Note Micro USB Port Replacement: 8 단계, 이미지 1/1
    • Remove the three 3mm screws on the bottom of the device with a Phillips #00 screwdriver.
  9. Samsung Galaxy Note Micro USB Port Replacement: 9 단계, 이미지 1/1
    • Remove the black rectangular bracket imprinted with a "7" where you just removed the screws. The piece should pop off easily.
    • Disconnect the antenna (white wire) with a spudger by prying the metal part gently off.
  10. Samsung Galaxy Note Micro USB Port Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Note Micro USB Port Replacement: 10 단계, 이미지 2/2
    • Slide spudger under the USB port and gently drag it left and right to remove the port from the phone.
    • Adhesive keeps the USB port from moving, so it might not pull up right away.
결론
다른 20명이 해당 안내서를 완성하였습니다.
David Ritter
회원 가입일: 04/14/13
758 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-45, Amido Spring 2013 Cal Poly, Team 3-45, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G45
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 6,667
