주요 콘텐츠로 건너뛰기
Samsung Galaxy Note20 USB-C Port Replacement
필요한 것
  1. Samsung Galaxy Note20 USB-C Port Replacement, Heat the rear cover: 1 단계, 이미지 1개 중 1개
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
  2. Samsung Galaxy Note20 USB-C Port Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 USB-C Port Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
  3. Samsung Galaxy Note20 USB-C Port Replacement, Begin to cut the adhesive: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Begin to cut the adhesive: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 USB-C Port Replacement, Begin to cut the adhesive: 3 단계, 이미지 3개 중 3개
    • As you cut through the adhesive around the perimeter of the phone, don't insert the pick more than 5 mm to avoid damaging internal components.
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note20 USB-C Port Replacement, Cut along the perimeter of the rear cover: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Cut along the perimeter of the rear cover: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 USB-C Port Replacement, Cut along the perimeter of the rear cover: 4 단계, 이미지 3개 중 3개
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
  5. Samsung Galaxy Note20 USB-C Port Replacement, Remove the rear cover: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Remove the rear cover: 5 단계, 이미지 2개 중 2개
    • Lift the rear cover straight up to remove it.
  6. Samsung Galaxy Note20 USB-C Port Replacement, Remove the motherboard shield: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
  7. Samsung Galaxy Note20 USB-C Port Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 USB-C Port Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift up and flip back the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
  8. Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the battery: 8 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the battery: 8 단계, 이미지 2개 중 2개
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the wireless charging coil: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the wireless charging coil: 9 단계, 이미지 2개 중 2개
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
  10. Samsung Galaxy Note20 USB-C Port Replacement, Remove the wireless charging coil: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Remove the wireless charging coil: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 USB-C Port Replacement, Remove the wireless charging coil: 10 단계, 이미지 3개 중 3개
    • Grip the motherboard shield with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the device with light adhesive.
    • Remove the wireless charging coil.
  11. Samsung Galaxy Note20 USB-C Port Replacement, Unscrew the loudspeaker: 11 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
  12. Samsung Galaxy Note20 USB-C Port Replacement, Remove the loudspeaker: 12 단계, 이미지 3개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Remove the loudspeaker: 12 단계, 이미지 3개 중 2개 Samsung Galaxy Note20 USB-C Port Replacement, Remove the loudspeaker: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
    • Use the spudger to pry up and detach the loudspeaker from the frame.
    • Use a pair of tweezers to lift and remove the loudspeaker.
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
  13. Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the interconnect cables: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the interconnect cables: 13 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
  14. Samsung Galaxy Note20 USB-C Port Replacement: 14 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement: 14 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
  15. Samsung Galaxy Note20 USB-C Port Replacement: 15 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement: 15 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
  16. Samsung Galaxy Note20 USB-C Port Replacement: 16 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement: 16 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
  17. Samsung Galaxy Note20 USB-C Port Replacement, Remove the daughterboard: 17 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 2.9 mm screw securing the daughterboard to the frame.
  18. Samsung Galaxy Note20 USB-C Port Replacement: 18 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement: 18 단계, 이미지 2개 중 2개
    • The daughterboard is fitted to the frame by three spring connectors along its bottom edge.
    • Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
    • Use the spudger to pry up and detach the daughterboard from the frame.
    • There are small surface-mounted components underneath the daughterboard. Only insert the spudger as far as necessary to avoid damaging the components.
  19. Samsung Galaxy Note20 USB-C Port Replacement: 19 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift and remove the daughterboard.
  20. Samsung Galaxy Note20 USB-C Port Replacement, Unscrew the USB-C port: 20 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 2.9 mm screws securing the USB-C port to the phone.
  21. Samsung Galaxy Note20 USB-C Port Replacement, Loosen the USB-C port: 21 단계, 이미지 2개 중 1개 Samsung Galaxy Note20 USB-C Port Replacement, Loosen the USB-C port: 21 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger under the right side screw hole on the USB-C port.
    • Pry up the USB-C port to loosen it from the frame.
    • The USB-C port may fling out of its slot while it is being pried.
    • The USB-C port is held in place by a red rubber gasket. Prying up with a steady force will gradually loosen the USB-C port from its slot.
  22. Samsung Galaxy Note20 USB-C Port Replacement, Remove the USB-C port: 22 단계, 이미지 1개 중 1개
    • Grip the USB-C cable with your fingers close to the USB-C port.
    • Remove the USB-C port by pulling it up and away from the bottom of the phone.
    • Avoid bending the ribbon cable more than necessary to prevent damage.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
다른 6명이 해당 안내서를 완성하였습니다.
Kyle Smith
회원 가입일: 02/01/21
49,187 평판
안내서 123개를 작성함
1가이드 댓글
The guide is good, was going to finish the guide while replacing the battery. However the cable connected to the USB-c port was (at least for me) soldered. I had to reinstall the old port until I can get my soldering iron. Will attempt soon. Otherwise great guide.
Yarran Byrne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 106
전체 시간: 9,330
