주요 콘텐츠로 건너뛰기
Samsung Galaxy S III Front Panel Assembly Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy S III Front Panel Assembly Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement, Rear Case: 1 단계, 이미지 2/2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Front Panel Assembly Replacement: 2 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 2 단계, 이미지 2/2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Front Panel Assembly Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 3 단계, 이미지 2/2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Front Panel Assembly Replacement: 4 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 4 단계, 이미지 2/2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Front Panel Assembly Replacement: 5 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 5 단계, 이미지 2/2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Front Panel Assembly Replacement, Battery: 6 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement, Battery: 6 단계, 이미지 2/2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Front Panel Assembly Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 7 단계, 이미지 2/2
    • Remove the battery.
  8. Samsung Galaxy S III Front Panel Assembly Replacement, SIM Card: 8 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement, SIM Card: 8 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement, SIM Card: 8 단계, 이미지 3/3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Front Panel Assembly Replacement: 9 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement: 9 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement: 9 단계, 이미지 3/3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Front Panel Assembly Replacement, microSD Card: 10 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement, microSD Card: 10 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement, microSD Card: 10 단계, 이미지 3/3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Front Panel Assembly Replacement: 11 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 11 단계, 이미지 2/2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Front Panel Assembly Replacement, Plastic Midframe: 12 단계, 이미지 1/1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Front Panel Assembly Replacement: 13 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 13 단계, 이미지 2/2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Front Panel Assembly Replacement, Headphone Jack/Speaker Assembly: 14 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement, Headphone Jack/Speaker Assembly: 14 단계, 이미지 2/2
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Front Panel Assembly Replacement: 15 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 15 단계, 이미지 2/2
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Front Panel Assembly Replacement: 16 단계, 이미지 1/1
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
  17. Samsung Galaxy S III Front Panel Assembly Replacement, Motherboard Assembly: 17 단계, 이미지 1/1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  18. Samsung Galaxy S III Front Panel Assembly Replacement: 18 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 18 단계, 이미지 2/2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  19. Samsung Galaxy S III Front Panel Assembly Replacement: 19 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 19 단계, 이미지 2/2
    • Disconnect the display data cable from the motherboard.
  20. Samsung Galaxy S III Front Panel Assembly Replacement: 20 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement: 20 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement: 20 단계, 이미지 3/3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  21. Samsung Galaxy S III Front Panel Assembly Replacement: 21 단계, 이미지 1/1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  22. Samsung Galaxy S III Front Panel Assembly Replacement: 22 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 22 단계, 이미지 2/2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
  23. Samsung Galaxy S III Front Panel Assembly Replacement, Front-Facing Camera: 23 단계, 이미지 1/1
    • Remove the single 2.0 mm Phillips screw securing the front-facing camera bracket to the front panel.
  24. Samsung Galaxy S III Front Panel Assembly Replacement: 24 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 24 단계, 이미지 2/2
    • Use a pair of tweezers to lift the front-facing camera/ambient light sensor/rear microphone assembly out from its socket in the front panel assembly.
  25. Samsung Galaxy S III Front Panel Assembly Replacement, Front Panel Assembly: 25 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement, Front Panel Assembly: 25 단계, 이미지 2/2
    • Peel the antenna cable up from its channel in the front panel assembly.
    • Do not completely remove the antenna cable, it is still connected to the antenna board.
  26. Samsung Galaxy S III Front Panel Assembly Replacement: 26 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 26 단계, 이미지 2/2
    • Wedge the tip of a spudger underneath the earpiece speaker and pry the earpiece speaker out of its recess in the front panel assembly.
  27. Samsung Galaxy S III Front Panel Assembly Replacement: 27 단계, 이미지 1/1
    • Use the flat edge of a spudger to peel the top portion of the earpiece/volume buttons/ambient light sensor ribbon cable from the front panel assembly.
  28. Samsung Galaxy S III Front Panel Assembly Replacement: 28 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 28 단계, 이미지 2/2
    • Carefully wedge the flat edge of a spudger underneath the ambient light sensor.
    • Continue peeling the earpiece/volume buttons/ambient light sensor ribbon cable up off the front panel assembly.
  29. Samsung Galaxy S III Front Panel Assembly Replacement: 29 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 29 단계, 이미지 2/2
    • Insert the flat edge of a spudger underneath the earpiece/volume buttons/ambient light sensor ribbon cable connector.
    • Gently run the spudger across to continue peeling the the earpiece/volume buttons/ambient light sensor ribbon cable from the front panel assembly.
  30. Samsung Galaxy S III Front Panel Assembly Replacement: 30 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement: 30 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement: 30 단계, 이미지 3/3
    • Insert a plastic opening tool in between the the buttons ribbon cable and the volume button.
    • Push the volume out of its recess in the front panel assembly.
    • Lift and remove the volume button out of the phone.
  31. Samsung Galaxy S III Front Panel Assembly Replacement: 31 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 31 단계, 이미지 2/2
    • Wedge the flat edge of a plastic opening tool in between the the earpiece/buttons/ambient light sensor ribbon cable and run it down to loosen the adhesive securing the ribbon cable.
  32. Samsung Galaxy S III Front Panel Assembly Replacement: 32 단계, 이미지 1/1
    • Grasp and remove the earpiece/buttons/ambient light sensor ribbon cable out of the phone.
  33. Samsung Galaxy S III Front Panel Assembly Replacement: 33 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement: 33 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement: 33 단계, 이미지 3/3
    • Use a metal spudger to carefully peel the antenna board off the front panel assembly.
    • Lift and remove the antenna board out of the phone.
  34. Samsung Galaxy S III Front Panel Assembly Replacement: 34 단계, 이미지 1/3 Samsung Galaxy S III Front Panel Assembly Replacement: 34 단계, 이미지 2/3 Samsung Galaxy S III Front Panel Assembly Replacement: 34 단계, 이미지 3/3
    • Push the power button out of its recess in the front panel assembly.
    • Remove the power button from the front panel assembly.
  35. Samsung Galaxy S III Front Panel Assembly Replacement: 35 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 35 단계, 이미지 2/2
    • Use the tip of a spudger to pry the vibrator out of its recess in the front panel assembly.
  36. Samsung Galaxy S III Front Panel Assembly Replacement: 36 단계, 이미지 1/2 Samsung Galaxy S III Front Panel Assembly Replacement: 36 단계, 이미지 2/2
    • Use the tip of a spudger to peel the vibrator assembly off the front panel assembly.
  37. Samsung Galaxy S III Front Panel Assembly Replacement: 37 단계, 이미지 1/1
    • Lift and remove the vibrator out of the front panel assembly.
  38. Samsung Galaxy S III Front Panel Assembly Replacement: 38 단계, 이미지 1/1
    • Front panel assembly remains.
    • If you are replacing the front panel assembly with a new one, don't forget to transfer all the parts you removed to your new front panel assembly.
결론
다른 212명이 해당 안내서를 완성하였습니다.
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 14개
Hi,
I wonder if this is guide to actually replace broken digitizer - if we have full Digitizer/LCD assembly?
Thanks
Akki S - 답글
I've just watched the video and... that was pure pleasure to watch repairer. She's professional and beautiful!
paczor - 답글
Thanks. This is the second time I've used this guide.
William Geisweit - 답글
And how Ill install thenew screen ?
Lea Efremov - 답글
Brilliant Step-By-Step guide. My phone needed new digitizer as just a black screen was showing when turned on, must have happened from a drop. I bought the digitizer screen combo from ebay and used this guide to dress across the components. Worked first time! There are a couple of other spongy or supportive rubber pieces around certain components that were in the original phone so I transferred those also, I guess they are there just to ensure tight connections etc. Absolute lifesaver!
James Lainchbury - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 33
전체 시간: 271,440
