주요 콘텐츠로 건너뛰기
Samsung Galaxy S10 SIM Card Replacement
필요한 것
  1. Samsung Galaxy S10 SIM Card Replacement, Remove the SIM tray: 1 단계, 이미지 1/3 Samsung Galaxy S10 SIM Card Replacement, Remove the SIM tray: 1 단계, 이미지 2/3 Samsung Galaxy S10 SIM Card Replacement, Remove the SIM tray: 1 단계, 이미지 3/3
    • Insert a SIM card eject tool, SIM eject bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress seal are mounted out of harm's way.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
결론
After you've completed the repair, follow this guide to test your repair.
다른 3명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,816 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
Bravi, guida semplice e perfetta, molto chiara. Complimenti!
lellacopabia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 36
7일 전: 267
30일 전: 1,391
전체 시간: 67,353
