소개
Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
도구
지정된 도구가 없습니다.
부품
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
다른 97명이 해당 안내서를 완성하였습니다.
댓글 한 개
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
