주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 Active Battery Replacement
필요한 것
  1. Samsung Galaxy S5 Active Battery Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: 1 단계, 이미지 3/3
    • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Active Battery Replacement, Battery: 2 단계, 이미지 1/3 Samsung Galaxy S5 Active Battery Replacement, Battery: 2 단계, 이미지 2/3 Samsung Galaxy S5 Active Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
결론
To install the new battery, follow these instructions in reverse order.
다른 11명이 해당 안내서를 완성하였습니다.
Nils David Corrales Tovar
회원 가입일: 09/22/14
3,198 평판
안내서 7개 작성하였습니다
USF Tampa, Team 1-5, Hickman Fall 2014 USF Tampa, Team 1-5, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Awesome! I called around to the “WeFixYourPhone” places and they told me that battery couldn’t be replaced in a Samsung S5 Active, or they’d replace it for $40 if I bought the battery. Battery $13.50 for a 3200 mAmp one, Amazon Primed it to me. And the 45 seconds to replace it is no joke. That’s all it took. It took longer to get the Otter Box off the phone.
Lisa Swager - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 27
전체 시간: 26,578
