이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
For the official iFixit guide to repair your Galaxy S5 nicroSD card, click here. The guide you are currently viewing is duplicate content, archived here for historical purposes only.
필요한 것
Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
Gently slide out the SD card using your fingernail or a plastic opening tool.
다른 5명이 해당 안내서를 완성하였습니다.
