주요 콘텐츠로 건너뛰기
Samsung Galaxy S8 Plus Display Assembly (With Frame) Replacement
필요한 것
동영상 지침
결론
다른 34명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
431,464 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,077개 작성하였습니다
댓글 5개
something to note, not sure if the guy mentions in video (it’s german, I didn't actually watch it) :
If you try and test the new display before you reassembled the mid frame, you will get a temperature warning. reinstall all screws and mid frame then test, should be good.
also, this is the only method you should attempt this repair, as the official samsung screens will come like this, with frame. If not, its not original, don’t waste your time or money on sh!tty parts
Andrew - 답글
Agreed! I love my OEM Samsung Service Box Display
Ethan Bain - 답글
Best video I’ve seen of the S8 teardown. Agree with what Andrew said above, check the midframe to see all the extra small parts are there. To check everything works, you can turn on the phone with after connecting the display to the motherboard, and puting the internals back together (everything but gluing the front and back pieces). Be careful to put all the screws back in place- the motherboard needs a tight connection to components on the midframe (like the power button and audio speaker) to work. Good luck!
Michael M - 답글
Can I buy the screen replacement
Christian lares - 답글
How can i by samsung Galaxy 8+ screen?
Nguse Hayelom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 24
30일 전: 133
전체 시간: 31,537
