소개
The SIM card tray houses both the SIM card for your cellular network as well as the (optional) SD card for expanded storage. Use this guide to eject the tray and remove or replace either card. The S8 and S8+ both use the same tray, so the same part is compatible with either phone.
필요한 것
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, on the top edge of the phone.
Press firmly to eject the tray.
After you've completed the repair, follow this guide to test your repair.
다른 6명이 해당 안내서를 완성하였습니다.
