이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
냄비나 팬에 iOpener가 완전히 잠길 정도로 충분한 물을 채우세요.
물이 끓을 때까지 가열하세요. 불을 끄세요.
iOpener를 뜨거운 물에 2~3분간 담그세요. iOpener가 물에 완전히 잠겼는지 확인합니다.
집게를 사용하여 뜨거운 물에서 가열된 아이오페너를 꺼내세요.
수건으로 iOpener를 완전히 말리세요.
iOpener를 사용할 준비가 되었습니다! iOpener를 재가열해야 한다면 물을 끓인 후 불을 끄고 2~3분 동안 iOpener를 물에 담가 두세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
Lift on the suction cup, and insert an opening pick under the rear glass.
Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Slide the opening pick down the side of the phone, separating the adhesive.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use the opening picks to slice through any remaining adhesive and open the phone slightly.
Remove the glass from the phone.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
Press to eject the tray.
Remove the SIM card tray from the phone.
Use the flat end of a spudger to disconnect the sensor array connector.
Use the flat end of a spudger to disconnect the front-facing camera connector.
Use the flat end of a spudger to disconnect the display and digitizer connector.
Use the point of a spudger to disconnect two antenna cables that connect the motherboard to the daughterboard.
Use the flat end of a spudger to disconnect an antenna ribbon cable that connects the motherboard to the daughterboard.
Use the flat end of a spudger to lift the motherboard and disconnect it from the daughterboard.
다른 13명이 해당 안내서를 완성하였습니다.
