이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
In the following steps, you'll be cutting through the adhesive securing the back cover.
You'll be slicing through the adhesive in the areas shown:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
Slide the opening pick from the bottom right corner along the side to the top.
Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
Carefully lift the side of the rear glass where the volume button is located.
Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
Take out the SIM card by using a SIM card remover or unbent paper clip to depress the release lever.
Remove the earpiece speaker by prying it off of the front display with the spudger.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 3개
Replaced ear speaker but ended up being a software issue ☹️
So do you have a software issue now, or did you not need to replace the earpiece speaker? Asking so I can help troubleshoot if necessary.
Hey, I just replaced the earpiece speaker as well and it does not work in phone calls, however, it does work to play music. I’m not sure what the issue could be here besides software related issues, however, I will try to reset the phone and let you guys know if that fixes it. If anyone has any ideas, I’m all ears.
DJ Dankman - 답글
