주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab 3 Kids Battery Replacement
필요한 것
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids  Battery Replacement: 2 단계, 이미지 2/2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids  Battery Replacement: 3 단계, 이미지 2/2
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab 3 Kids  Battery Replacement: 4 단계, 이미지 2/2
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
결론
다른 4명이 해당 안내서를 완성하였습니다.
ajhoffman
회원 가입일: 01/04/14
182 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-6, Nance Fall 2016 USF Tampa, Team 2-6, Nance Fall 2016 회원
USFT-NANCE-F16S2G6
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - 답글
my screen broke
galixyman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 18
전체 시간: 1,985
