주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 10.1 Speaker Replacement
필요한 것
  1. Samsung Galaxy Tab A 10.1 Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Speaker Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Speaker Replacement: 2 단계, 이미지 2/2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Speaker Replacement, Disconnecting the battery: 3 단계, 이미지 1/1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Speaker Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Speaker Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab A 10.1 Speaker Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab A 10.1 Speaker Replacement: 5 단계, 이미지 3/3
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Speaker Replacement, Battery removal: 6 단계, 이미지 1/2 Samsung Galaxy Tab A 10.1 Speaker Replacement, Battery removal: 6 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • Use Phillips # 000 to remove the 4 mm .3 cm screw on each speaker.
    • If you encounter a stripped screw, see iFixit’s guide on how to remove it here.
  8. Samsung Galaxy Tab A 10.1 Speaker Replacement: 8 단계, 이미지 1/1
    • Place the plastic opening tool on the edge of the speaker.
    • Lodge the plastic opening tool under each speaker and lift them up and out of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Isabella Li
회원 가입일: 10/02/17
2,364 평판
안내서 7개 작성하였습니다
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G6
4 회원들
안내서 26개 작성하였습니다
댓글 2개
Where is a good place to buy the replacement speaker?
Max Alberts - 답글
Where is a good place to buy a speaker?
Max Alberts - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 29
전체 시간: 4,119
