주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement
필요한 것
  1. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: 1 단계, 이미지 3/3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 2 단계, 이미지 2/2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: 3 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: 3 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: 3 단계, 이미지 3/3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: 9 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a soldering iron to heat 4 spots of solder from the motherboard.
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Use precision tweezers to remove the charging port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Nolan
회원 가입일: 02/17/17
805 평판
안내서 5개 작성하였습니다
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 6,603
