주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement
필요한 것
  1. Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement, Screen: 1 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement: 2 단계, 이미지 2/2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement: 3 단계, 이미지 1/1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Screen Replacement: 5 단계, 이미지 1/1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joy Harris
회원 가입일: 02/15/17
814 평판
안내서 7개 작성하였습니다
USF Tampa, Team S3-G4, Sullivan Spring 2017 USF Tampa, Team S3-G4, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G4
3 회원들
안내서 14개 작성하였습니다
댓글 3개
Hí, my Tab S2 has been to a Samsung Service Center for screen replacement, after which they had to open it again, they were not very skilled professionals, and now my screen is not attached to the frame, it is popping out on all sides. Is there a way to glue in the display? Is there a replacement adhesive available?
Gabor - 답글
Hi, my Samsung Tab S2 9.7 has been at a Samsung shop for a new LCD, and they had to reopen it again after the new display has been installed. They were not very skilled professionals. Now my display is not attached to the frame properly and is lifting 1-2mm out of the frame, on all sides, and feels loose. Is there a replacement adhesive to attach the display properly? Or is there some other way to glue in the display? Thanks.
Gabor - 답글
Thanks For this update
I Got AT&T Internet From AT&T Internet Deals
John Fernando - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 32
전체 시간: 2,496
