주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement
필요한 것
  1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: 1 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: 1 단계, 이미지 2/2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 2 단계, 이미지 2/2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 3 단계, 이미지 1/1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 5 단계, 이미지 1/1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: 6 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: 6 단계, 이미지 2/2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 7 단계, 이미지 3/3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: 8 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: 8 단계, 이미지 2/2
    • Locate the speakers towards the bottom.
    • For the speaker on the left, use the plastic opening tool to lift up the press-fit connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 9 단계, 이미지 2/2
    • Apply the iOpener to the magnet to loosen the adhesive glue.
    • Refer to the iOpener guide for more help.
    • If you do not have access to an iOpener, you may also use a heat gun or a hair dryer.
  10. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 10 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the precision tweezers, remove the speaker.
  11. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 11 단계, 이미지 2/2
    • For the speaker on the right, use the plastic opening tool to lift up the press-fit connector.
    • Using the precision tweezers, detach the orange cable.
  12. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 12 단계, 이미지 1/1
    • Pull the orange ribbon cable out of the ZIF connector using the precision tweezers.
    • Be gentle so that you do not damage the orange ribbon cable.
  13. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 13 단계, 이미지 1/1
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joy Harris
회원 가입일: 02/15/17
814 평판
안내서 7개 작성하였습니다
USF Tampa, Team S3-G4, Sullivan Spring 2017 USF Tampa, Team S3-G4, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 17
전체 시간: 1,259
