주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement
필요한 것
  1. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement, Screen: 1 단계, 이미지 1/1
    • Heat the iOpeners in a microwave for 1-2 minutes.
    • The iOpeners will be hot. Use caution and hold the tabs on the ends.
    • Place heated iOpeners on screen edges to heat the adhesive.
    • For more detailed instructions on how to use the iOpeners, please refer to the iOpener Instructions.
  2. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 2 단계, 이미지 1/1
    • Separate the screen assembly from the back by wedging the picks between the two components.
    • Slide the picks along the edge and leave them holding the device open all around the edges.
  3. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 3 단계, 이미지 1/1
    • Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
    • Insert the picks to hold the two components apart once a gap is created.
  4. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 4 단계, 이미지 1/1
    • Once all edges have been disconnected, carefully lift the screen off by pulling one side up.
    • Be careful not to cut yourself. Any broken glass from the screen will be sharp.
  5. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, gently peel up on the silver tape covering the connector.
  6. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to get under the connector piece. This will allow you to remove the front panel assembly from the rest of the device.
  7. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 7 단계, 이미지 1/1
    • Detach the connecter from the inside of the device.
    • Lift the screen to separate the front panel assembly from the rest of the device.
  8. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement, Central Panel: 8 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement, Central Panel: 8 단계, 이미지 2/2
    • Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
    • For additional information on how to remove screws, please refer to Screwdriver Best Practices.
  9. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 9 단계, 이미지 2/2
    • Remove the 2 centrally-located black 3.0 mm Phillips head screws using the screwdriver.
  10. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 10 단계, 이미지 2/2
    • Use the plastic opening tools to gently separate the middle panel from the rest of the device.
    • Move the tool around under the edges until you can remove the panel by hand.
    • Popping/cracking noises are completely normal. These are the sounds of the panel separating from the rest of the device.
  11. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 11 단계, 이미지 3/3
    • Lift up the central panel starting from one corner to separate it from the rest of the device.
    • Pull towards the top of the device as you lift out to ensure that the charging port connection is not damaged.
  12. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement, SD Card Reader: 12 단계, 이미지 1/3 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement, SD Card Reader: 12 단계, 이미지 2/3 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement, SD Card Reader: 12 단계, 이미지 3/3
    • Insert the pointed end of the black spudger into the hole located on the right side of the device.
    • Use the spudger as a lever to remover the SD Card plastic piece from the reader.
  13. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 13 단계, 이미지 1/3 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 13 단계, 이미지 2/3 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 13 단계, 이미지 3/3
    • Use the plastic opening tool to unlock the SD card reader from the back panel.
    • Wedge the tool under the reader and gently lift up to pop it out.
  14. Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 14 단계, 이미지 1/2 Samsung Galaxy Tab S2 9.7 SM-T813 SD Card Reader Replacement: 14 단계, 이미지 2/2
    • Pick up the SD card reader with your fingers. There is no adhesive, so the reader will come off easily.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nash Elder
회원 가입일: 04/18/18
779 평판
안내서 4개 작성하였습니다
Cal Poly, Team S16-G5, Livingston Spring 2018 Cal Poly, Team S16-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G5
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 24
전체 시간: 1,815
