주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S3 Headphone Jack Replacement
필요한 것
  1. Samsung Galaxy Tab S3 Headphone Jack Replacement, Display: 1 단계, 이미지 1/1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Headphone Jack Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Headphone Jack Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Tab S3 Headphone Jack Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Tab S3 Headphone Jack Replacement: 4 단계, 이미지 3/3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Headphone Jack Replacement, Rear glass panel: 5 단계, 이미지 1/2 Samsung Galaxy Tab S3 Headphone Jack Replacement, Rear glass panel: 5 단계, 이미지 2/2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Headphone Jack Replacement, Battery: 6 단계, 이미지 1/2 Samsung Galaxy Tab S3 Headphone Jack Replacement, Battery: 6 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Headphone Jack Replacement: 7 단계, 이미지 1/1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Headphone Jack Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab S3 Headphone Jack Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab S3 Headphone Jack Replacement: 8 단계, 이미지 3/3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Headphone Jack Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab S3 Headphone Jack Replacement: 9 단계, 이미지 2/2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Headphone Jack Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab S3 Headphone Jack Replacement: 10 단계, 이미지 2/2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Headphone Jack Replacement: 11 단계, 이미지 1/1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Headphone Jack Replacement, Headphone Jack: 12 단계, 이미지 1/3 Samsung Galaxy Tab S3 Headphone Jack Replacement, Headphone Jack: 12 단계, 이미지 2/3 Samsung Galaxy Tab S3 Headphone Jack Replacement, Headphone Jack: 12 단계, 이미지 3/3
    • Insert the pointy end of the spudger into the headphone jack.
    • Lift the spudger up to snap the headphone jack module off of the motherboard.
    • Be careful to avoid inserting the spudger too far or applying excessive force, as this may damage the inside of the headphone jack.
  13. Samsung Galaxy Tab S3 Headphone Jack Replacement: 13 단계, 이미지 1/2 Samsung Galaxy Tab S3 Headphone Jack Replacement: 13 단계, 이미지 2/2
    • Use the flat end of the spudger to snap the ribbon connector off of the motherboard.
  14. Samsung Galaxy Tab S3 Headphone Jack Replacement: 14 단계, 이미지 1/1
    • Remove the headphone jack from the device.
결론
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
다른 한 분이 해당 안내서를 완성하였습니다.
Mimi Fucini
회원 가입일: 04/18/18
684 평판
안내서 4개 작성하였습니다
Cal Poly, Team S22-G4, Maness Spring 2018 Cal Poly, Team S22-G4, Maness Spring 2018 회원
CPSU-MANESS-S18S22G4
5 회원들
안내서 15개 작성하였습니다
댓글 한 개
This repair can be done without removing the screen!
hansderaedt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 10
전체 시간: 849
