소개
If you are a constant headphone user, the jack on your Galaxy Tab S3 can get worn out over time. If you have already tried cleaning the debris out of the headphone jack with a toothpick and it still doesn't work, you may need to replace the jack. This guide will show you how to properly remove and replace the headphone jack module.
필요한 것
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
이 단계에 사용된 도구:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Insert the pointy end of the spudger into the headphone jack.
Lift the spudger up to snap the headphone jack module off of the motherboard.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
다른 한 분이 해당 안내서를 완성하였습니다.
There is no reason to remove the screen while replacing a battery.
Nick Youngstrom - 답글
Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
Phenix City - 답글
