이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
이 단계에 사용된 도구:Plastic Cards$2.99-
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Pull off the glass panel using the suction cup.
Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
Disconnect the single press fit connector located just above the Micro SD card tray on the left midframe.
Next pry the Micro SD card tray up from the midframe on the left with your finger.
Remove the Micro SD card reader.
다른 2명이 해당 안내서를 완성하였습니다.
