주요 콘텐츠로 건너뛰기
Samsung Galaxy Watch Active2 Battery Replacement
필요한 것
  1. Samsung Galaxy Watch Active2 Battery Replacement, Turn off the watch: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Turn off the watch: 1 단계, 이미지 2개 중 2개
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Battery Replacement, Remove the rear screws: 2 단계, 이미지 1개 중 1개
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Battery Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Watch Active2 Battery Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 3개
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 2개
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Battery Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the display and speaker: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the display and speaker: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the display and speaker: 6 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the barometric sensor, buttons, and mic: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the barometric sensor, buttons, and mic: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the barometric sensor, buttons, and mic: 7 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Battery Replacement, Lift the core assembly: 8 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Lift the core assembly: 8 단계, 이미지 2개 중 2개
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Battery Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Watch Active2 Battery Replacement, Remove the core assembly: 9 단계, 이미지 3개 중 3개
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Battery Replacement, Flip the Core Assembly: 10 단계, 이미지 1개 중 1개
    • Flip the core assembly over so the motherboard faces down.
  11. Samsung Galaxy Watch Active2 Battery Replacement, Undo the top button: 11 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Undo the top button: 11 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to peel the top button off the plastic frame.
  12. Samsung Galaxy Watch Active2 Battery Replacement, Remove the motherboard screw: 12 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  13. Samsung Galaxy Watch Active2 Battery Replacement, Free the motherboard: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Free the motherboard: 13 단계, 이미지 2개 중 2개
    • Place the flat end of a spudger between the motherboard and the plastic frame near the copper coil at the bottom right.
    • Twist the spudger to free the motherboard from the plastic tabs.
  14. Samsung Galaxy Watch Active2 Battery Replacement, Remove the motherboard: 14 단계, 이미지 1개 중 1개
    • Slide the motherboard out from under the remaining plastic tabs to remove it.
  15. Samsung Galaxy Watch Active2 Battery Replacement, Lift the battery: 15 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Lift the battery: 15 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger between the bottom of the battery and the core frame.
    • The battery is secured with some mild adhesive. If the adhesive is too strong you can use a hair dryer to soften it.
    • Use the spudger to lever up the battery.
    • Take care not to puncture or bend the battery. Only use plastic tools. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
  16. Samsung Galaxy Watch Active2 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 1개 Samsung Galaxy Watch Active2 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 2개 Samsung Galaxy Watch Active2 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to grab the connector and slowly pull it off the core frame.
    • The battery connector is affixed with mild adhesive.
    • Remove the battery from the core assembly.
    • When installing a new battery make sure the tiny hole on the battery connector aligns with the pin on the core frame.
결론
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 33명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,229 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
19가이드 댓글
Hi. How can I distinguish between battery rather than motherboard disfunción? My watch doesn't charge anymore. It appears to start charging but doesn't.
Dan Frank - 답글
It doesn't appear swollen either. Took to the beach and swam on salty water and pool… didn't work after.
Dan Frank -
This is the SAME thing that is happening to me. Went to the beach, on the drive home it died, hasn’t charged since. I set it on the charger and it will say 0%, but never charge enough to power on. I took to best buy and they said I need to buy a new watch :(. Would also like to know if you think it is the battery or if the beach water could have fried the whole thing. I wouldn’t think it would since it occasionally will flash the 0% when try to charge it.
Branddy Hopkins - 답글
Exact same thing in two separate cases. That's it. 0% flashing sometimes and completely dead. And as it seems nobody but us is posting our sad stories. We need to look further and find something on YouTube or online… there must be something…
Dan Frank -
I have been looking online and it seems that the battery has lower charge than what is chargeable. And by going deeper it also seems that there is a way to recharge that same battery at least to the point we're it might start again.
Dan Frank -
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 120
지난 30일: 566
전체 시간: 70,850
